DRL lamps
Lawce
Construction Site Manager
:(image.webp I need to upgrade my drl lamps as the vw ones are p--, I've been reading forum posts and wondered if we had got any further on the subject? I think the above puts it simply enough:(
As you have added your own LED DRLs why not disable the dim dip ones?
I would like them all on , but in the mean time how do I do that, or am I about to have a blonde moment?
They can only be turned off by programming via a computer with VCDS or of course by turning on your sidelights
Havent gone far down the LED route too much cheap crap around, have been trying out some normal style xenon/ice white lamps and only ones i havent got are DRL lamps :(
:cry: Ok just keep me up to date if that changes, I will keep digging and let you know if I crack it
What about headlight, sidelight and fog lamps ?
Have you still got the standard yellow ones
Is there a recommended bulb make/type upgrade list yet so you can self source if necessary?
Sorry if I've missed this info previously!
Yes Pauly everything is standard yellow and the only thing I don't like that vw did to the van, everything else is spot on, only slightly brighter than my mk1 and that's 35 yrs old:(
With reference to the DLR's can you not just remove the fuse like you could on the 5.1? That's what I done and just had the led DLR's on
Finally found some DRL bulbs in white instead of the insipid yellow ones in the velle..
what a complete nightmare to fit..
not impressed VW..
