Hi all,
I’m in the process of converting a T6.1 into a kombi and have a question about dropping the fuel tank to fit the seat brackets. I’ve read a few threads on here about doing this but have ended up a little confused.
In one thread I read that as long as you lower the tank carefully then you don’t need to disconnect anything but when I’ve started to do that I can see a black line from the tank that is connected to the frame of the van:
Can I disconnect this easily enough without causing any issues?
If this is disconnected will I then be able to lower without disconnecting the fuel lines which I think are the black, blue (and electric connections) here:
I’m a little hesitant as I changed the fuel filter in my golf once, got air in the system and had to call someone out to get it going again
Many thanks for any help!
