A Google AI result for Transport mode.
VW T6 factory transport mode is a "sleep" mode that shuts down most electrical systems to conserve battery charge during shipping and storage. It is intended for use by the factory and official service centers with specialized diagnostic tools, not for manual activation or deactivation by the owner.
Symptoms of transport mode
If your VW T6 is still in transport mode, you may experience some of the following issues:
A battery voltage display on the vehicle's multi-function display (MDF).
Multiple electrical system warnings, such as for the infotainment system, tire pressure monitoring, or parking aids.
The start-stop function may not work correctly or may show an error.
Reduced power output and other drivetrain limitations.
Non-functional comfort features, such as heated mirrors.
How to deactivate factory transport mode
Disabling factory transport mode requires a professional-grade diagnostic tool, such as Ross-Tech's VCDS or the dealer-level VAS tester. Unlike some vehicles that allow for a manual reset, the VW T6 requires a workshop visit for proper deactivation.
Using a diagnostic tool (professional)
Connect the tool: Plug the diagnostic tool into the vehicle's OBD-II port.
Access the function: Navigate to the "Applications" screen within the diagnostic software and select "Transport Mode".
Deactivate: Choose the "De-Activate Transport Mode" option to wake up all the vehicle's systems.
Confirm: Follow any on-screen prompts to confirm the deactivation.
What to do if you suspect your T6 is in transport mode
Contact a dealer: This is the most reliable method for deactivating transport mode, as they have the factory-approved tools and knowledge.
Consult a specialist: An independent VW specialist with a VCDS or similar professional tool can also perform the deactivation.
Avoid DIY fixes: Many online videos demonstrate manual reset procedures for other VW models (e.g., pumping the accelerator). These will not work for the T6's factory transport mode and are not recommended.
Factory transport mode vs. economy driving mode
Transport mode is not the same as the "Eco" or "Economy" driving mode available on some T6 models.
Transport Mode: A dormant state for shipping that turns off most electronics to save the battery and must be professionally deactivated.
Economy Mode: A normal driving mode that adjusts engine and transmission parameters to maximize fuel efficiency, which can be selected and deselected by the driver.
