First post here.
I’ve got a 2016 T6 conversion with a PMS3 control panel and a combi master relay which I think controls the fridge. Other than a currently not working solar panel with an opti-solar MPPT controller, I can’t immediately see any other leisure battery charging equipment. The van has a smart alternator.
I am now starting to think about a winter project to install a DC-DC charger and have read many of the threads here on the subject.
At this stage I would like if possible to just install the charger (probably Victron) and touch as little of the rest of the installation as possible. This being so:
1. What if anything do I need to do with the combi-master fridge relay?
2. Should I have another split charge relay somewhere?
2. What if anything do I need to do with the PMS3?
I have established from a supplier that I can leave the solar charging circuit as is (I will just replace the pv panel).
Any suggestions will be appreciated.
Thank you.
Thank you.
