Ctek charger
Bargy62
nutter
T6 Legend
I have a ctek mxs 7.0 with power supply mode and want to connect the ctek comfort connect cigarette lighter outlet as a 12volt outlet BUT both the charger and the cigarette lighter outlet have the same female connections so wont join any ideas on what is the correct part with Male connector or is it just not possible as someones already tried it or I've just got the wrong bit
I’m not sure you can do what you are trying to do. You can get a cigarette lighter adaptor to connect the charger into the vehicle 12v socket and charge the battery that way. I believe the one you have is intended to connect to the battery using the CTEK adaptor (i.e. that the charger would connect to). THis then allows you to connect 12v accessories to the battery (not to the charger)
