Ctek 250
sam_payne4
Hi, I’m installing a Ctek 250 into my t6.1 and was wondering what fuse people use to piggy back off for the ignition feed? Many thanks
I’ve installed the same in my T6.1 a few months back. Sorry to clarify but when you say ignition feed, do you mean the signal that tells the CTEK the engine is running.
Yes the wire that you run to the fuse box, I can’t seem to find a fuse board layout anywhere to know which fuse to use?
Ah. I see. I’m guessing you don’t have the factory leisure battery fitted but are adding a LB. If that’s the case I can’t help you straight off my head. I specced my T6.1 with OEM LB so I simply replaced the SCR fir the CTEK. Sorry to state the obvious. But if you search ‘DC to DC charger’ and ‘Engine Running Signal’ or similar, you’ll get loads of info. Again apologies as I did a straight swap which was EPLS.
Here’s a link fir a starter for ten.
