Corner assist fog lights stopped working
danncus
Hi. I’ve realised that the corner assist function has stoped working.
It’s enabled via Carista.
The most likely reason I can think of is that I’ve fitted the H7 headlights fitted with LED bulbs, I believe these have been ‘coded out’ and there is no bulb failure dashboard warning. But if I read the codes there’s bulb failure logged which I cannot delete with Carista
Is it possible to permanently remove the failure test with VCDS or OBD11?
