Ok, big problem here Guys,
I done some work on my Caravelle and very likely messed up something, but no ide what it could be.
I Completely rebuilt the suspension. New coilovers. the fronts with new bearing set, new bushes all around. tie rods, track rods steering rack ,brake kit upgrade. the o/s driveshaft come out as well. Also got brand new set of wheels with new premium tyres, rear wheel bearings
It went through MOT and today I did the wheel alignment.
it drives horrible something makes the front jiggle. It is very noticeable above 30 mph. The whole body shakin
the top of that. I got the fallowing fault codes:
The faults come back straight after I delete them and I cannot reset TPMS
Address 03: ABS Brakes Labels: 7E0-907-37X-MK100ESC.CLB
Control Module Part Number: 7E0 907 379 P HW: 7E0 907 379 M
Component and/or Version: ESC H06 0133
Software Coding: 307E4098256384800C75027BA48321D3790050
Work Shop Code: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001 (VN75)
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FCE41B4A6F0B063F2-806A
2 Faults Found:
0295 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 154
Mileage: 124847 km
Date: 2089.14.27
Time: 17:40:06
8324 - Databus
U1122 00 [10001001] - Implausible Message
[ACAN: LW1_ID wrong value]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 154
Mileage: 124847 km
Date: 2089.14.27
Time: 17:40:06
Address 01: Engine Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 KH HW: 04L 907 445
Component and/or Version: R4 2.0l TDI H02 6184
Software Coding: 0025401C433501080000
Work Shop Code: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KH 004013 (VN75)
ROD: EV_ECM20TDI03004L906056KF.rod
VCID: 7DB2FBBCEC7C6273A0-8028
1 Fault Found:
25126 - Implausible Data Received from ESP Control Module
U0416 00 [00100011] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 124847 km
Date: 2089.01.27
Time: 17:38:22
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 83 °C
Intake air temperature: 20 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.257 V
Unlearning counter according OBD: 40
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status: main switch off
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: N/A
Address 09: Cent. Elect. Labels: 7E0-937-BCM-V1.clb
Control Module Part Number: 7E0 937 090 B HW: 7E0 937 090
Component and/or Version: BCM PQ25 Max4 H81 0744
Software Coding: B8FE793A0A61341393288F447CEB9EF50D84698960CC6960320403BF0840
Work Shop Code: WSC 02737 534 594853
VCID: 2A1800E0457225CBB5-807E
1 Fault Found:
01838 - Transceiver Module 2 for Interior Monitoring (G305)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 124845 km
Time Indication: 0
Date: 2025.14.27
Time: 17:22:25
I would appreciate any input
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 154
Mileage: 124847 km
Date: 2089.14.27
Time: 17:40:06
8324 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 154
Mileage: 124847 km
Date: 2089.14.27
Time: 17:40:06
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 124847 km
Date: 2089.01.27
Time: 17:38:22
Readiness: N/A
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 124845 km
Time Indication: 0
Date: 2025.14.27
Time: 17:22:25
