Coilover adjustment advice
CarpyT6
Team Reflex Silver
Hi peeps, i was after some advice on adjusting the rear height on my coilovers. I want to lower the rear slightly so it sits level with the front. Is it a case of just winding up the adjuster marked with a white arrow in the photo attached. I'm not sure what brand of coilovers they are, they were already on the van. Any help greatly appreciated. Thanks
You wind that ring that the spring is butted against up the way to lower the van.
In my experience I have to undo one end of my damper to do it though as my spring is under a serious amount of pressure.
Yes you are correct. However top adjuster ring should be tight against the lower one to lock them in place.
You will probably have to get both rear wheels off the ground at the same time in order to unbolt the bottom damper bolts as the anti roll bar will work against you otherwise., the rear adjustment is not a direct correlation between amount the collar is moved vs amount the wheel moves, because the spring is in between the fulcrum point and the end of the lever so adjust smaller amount than you think you need.
May not be so. Depending on what set up you have sometimes there is only 1 adjuster ring.
My set up has only 1 adjuster.
