Wojtasjimf
Hello.
I was using my lps and I have a problems...on the video you can see what’s happened.
Its starting , about 20 sec and it’s restarting by itself and again and again… so I can’t use it anymore…
On this video you can see the lamps being powered directly from the LPS.
The lamps are not lighting properly, they are flickering — and the LEDs used to ignite the lamps are brightening and dimming.
In this video you can see how the power menu option doesn’t want to turn off. It keeps coming back, which prevents me from accessing the menu.
After some time, when I tried to enter the menu again, the LPS shut down.
In this video you can see how I’m trying to turn on the LPS, but unfortunately it’s difficult. The power button seems like it doesn’t want to respond. The LPS starts up, and I turned on the microwave to check whether the power was working, and everything was fine.
I would like to point out that I previously replaced all the fuses on the back of the LPS. I disconnected all the cables at the back, and the issue with the power menu was the same as it is now — I couldn’t turn it off, or it would come back very quickly, and the LPS would reset in this mode.
I turn it on, it works for 15–20 seconds, then resets. It turns on itself, it works for 15–20 seconds, then resets.
I also have a question, is here someone who can check it for me? I will pay all costs.
Right now it’s not loading from my car, but all cables are like always and I have last 30% of Battery.
Let me know please,
Let me know please,
