Chris' Candy White T6 Project
Fitted the new rear THQ lights yesterday along with the threshold cover to hide some scrapes.
Then the single seat arrived from @Rusty#Nuts (lighting making it looked marked but its not)
Then this unfortunately........ Had the coil light warning flash up with limited revs. Restarted engine and seemed OK. Got home, plugged it in and........... P164B00
Hello. Newbie here. What app and ODB2 module are you using?
Little update as the internal conversion starts............
Started the process of the power side of the conversion. Going to buy all the parts, get it wired and then order the furniture from Evo. Trying to plan this build a lot better than my last where I normally just go 'gung-ho' :think smile bounce:
So 300ah battery and a 2kw Inverter. Already have DC/DC and MPPT in place from previous owner
Going to start planning the wiring side now and hopefully run all the cables and leave them in situ ready for when I order and build the Evo kitchen.
My biggest challenge is storage on this build, im not going to have much because I want only low level kitchen
So that leaves the two 'ticked' areas for all my equipment - Going to have to pack very lightly!
Top loading Vitrifigo TL43 fridge will be the weapon of choice and I'll be gassless so just a small sink and induction hob recessed into the worktop.
Im 'hoping' to put my battery next to the tambour door and have some sort of enclosure for it and then mount the inverter above but its going to be very tight, need to check dimensions.
Hmm might have to re-think the inverter location. Only leaves 65mm between battery and inverter and that doesn't account for terminals or anything....
The joys of being a CAD Technician is I can draw and check :cool:
