Vdubster
CBE 25 Amp Consumer Unit Help.
HI i bought a CBE Power management kit, it seems its quite hard work as it the circuit breaker came with 0 insutrctions and i cannot find a thing online in regards to it.
Would i be correct in thinking the 240v "In" wiring goes in the bottom left socket/unit with the earth splitting off to the bottom left earth/ground bar? in turn i then need to run a earth from this bar to a ground point on the vehicle?
( the wires in the picture were already fitted )
do i then run my 240v out cables from the white socket/connections shown in the bottom right?
I assume it gives me 25 amp spread across these 4 outlets to wire up to sockets and or etc as i need?
My main question is with the outgoing 240v connections, does the earth for them need to be run to the bottom left earth bar? or is it fitted with to the 3 pin connectors on the bottom right alongside the live and neutral? thanks for any help or advise!
