Hi Guys,
I have a bullfinch shower that is only connected to the cold outlet, should I be terminating the hot inlet for the shower with one of these:
seamarknunn.com
Reason I ask is if I turn the shower connector slightly too far to the hot / red side, water sprays out the back of the unit from the hot inlet pipe.
Any help is greatly appreciated.
t2k2
Whale Quick Connect End Stop 15mm WX1546
Whale Quick Connect End Stop 15mm WX1546Also compatible with John Guest semi rigid pipe
seamarknunn.com
t2k2
