Bulkhead
ScottT6
hi just speccing a t6 bit worried on leg room,panel van with a bulkhead,does anyone think its possible to remove existing bulkhead and pack it out a couple of inches then refix?
or best to just not spec and build a timber one,
Previously had a t5 kombi wasn't an Issue,seems a tight squeeze in a panel van wth bulk cheers
Evening Scott
I had a caddy maxi previously
Just got my T6 LWB 140 high line
Panel van
With factory bulkhead
I'm a 6' 2" joiner....and find the van perfect
Not crampt.....and a really good driving position
Trust me...in my car that we got which is a polo tsk 2016...I have it reclined where my wife says ..do you sleep in this love.
Which I love because it's not work
In the van...especially with twin armrests and elevated driving position...makes sense to be a bit more armchaired
Problem with packing it forward is
1....it will impead the side loading door
2....the load length will be reduced.
3...and it connects securely and perfectly with a plastic trim at the top and securely at the bottom to the van.
You will lose this if moved.
Hope this helps
GRUFF
Evening Scott
Panel van
Hope this helps
GRUFF
cheers gruff,
makes sense i didn't consider the side doors, off to the stealers this wk so i jump in a few to check.
thanks again for your input pal
