Does anyone know if it’s possible to fit Brembo BM5 front brake calipers to a t6? Obviously some sort of adapter would be required but I’m not having much luck. They are 4 pot originally from a vw Touareg 3.0tdi.
finding someone to supply the brackets could be the issue and then what discs do you use?
i fitted the Brembo 6 pots with brackets from Germany. Uses Merc ML discs modded to suit
