Bonnet solar
Very nice, but £304 for a 80w panel and bit of vinyl is serious money.
50wbup is needed for a starter trickle charger.
£257 panel only is getting better....
But then they want 30£ delivery.
So still 287
It’s going to get all the stone damage that the bonnet would otherwise take.
The bonnet maybe partly insulated but it’s still getting hot which will reduce the panels efficiency.
Plus a few thousand squashed insects.
Way too much £ for such a small area.
Is this intended as a permanent install then? I was assuming it was temporary for when you are parked up.
If that’s the case then another negative is that it’s fugly!
