Bolt/Screw identification
denz1968
Could anyone please tell me what bolt head this is. I have tried torx and hex but neither seem to be correct.
It is the rear OS heat shield near back bumper
there plastic press/push fixings.
they will unscrew with a Torx or alan key bit, but you might need to get a fork trim tool under to get some leverage. . . ( but
Replacement clips ordered. Thanks for the amazon link
Now to work out the best route into the van for my EHU, and where to mount it in this area.
ThanksView attachment 194588
If these are the same as the rear oem headlining and panels I found it easier to clamp a screw in a molegrips screw it in 3-4 times and just pull had them all out in minutes
