chrishay321
Hi All
i have what seems to be a rather unusual issue with my 2013 2.0 Bi-Turbo CFCA Shuttle, it was driving fine them without warning it just stalled, and has not run since, it will start and run for about 5 seconds then stalls. there were 2 codes in after its initial stop but after clearing those they have not reappeared, and no other codes have been reported
the initial 2 codes were:
"mass or volume air flow circuit intermittent" and "ECM/PCM power relay de-energized performance - too early"
i have disconnected the MAF sensor (no change), i have changed the fuel pressure regulator (no change), disconnected the EGR (no change), disconnected the exhaust / DPF (no change) and disconnected the turbo / intercooler (no change)
i disconnected each injector in turn, injector 4 (no change), injector 3 (no change) injector 2 (it will not start at all) and infector 1 (will not start at all)
i did a leak down test and got hardly and fuel coming out of the injectors (but as it does not run for very long at all i assumed that was normal)
any ideas or suggestions would be greatly appreciated
thanks
thanks
