Went for the Halfords (Yuasa) AGM115 in the end. Swapped and coded this morning. Literally just needed to set the time and that’s it. Happy days. Cheers guys.
It was the first thing I did when turning ignition on after fitting. Was second nature but totally appreciate you advising as could have been very useful and will be to there no doubt.
am I reading correctly that changing the battery requires a re-coding. I am looking at various makes any suggestions please. Valta, yuasa, drive tec etc. and should I go slightly bigger.
My advice fwiw is fit the biggest AGM battery that will fit. Code it if possible, don’t worry too much if you can’t, the van will adapt itself after a few runs.
