Battery issue
Thomo
Hi there. New to the forum. Hoping someone more clued up than myself can provide a bit of insight.
For a few weeks now sometimes the battery seems a bit sluggish when starting (not all the time)
Last week after a long run with no issues starting the van at the beginning of the day my wife parked up briefly for 15 minutes or so then when she returned to the vehicle the van would start.
Started with a jump from a booster pack.
After driving home 2.5 miles the Van sat at my house for the next five days and last night it started no problem. I didn’t drive it, I was putting a battery voltage meter on it.
This morning it started again. Voltage when engine was off was 12V and when engine was on was reading 13V.
I understand this is lower than it should be however if the alternator was faulty would the voltage have increase to 13V?
Also when engine off battery indicator on the pack I connected to check the voltage stated 60% but when engine was on this changed to 100%.
I’m unsure how to proceed. Initially I was going to fit a new battery but am feeling that if the battery was faulty it wouldn’t have started after sitting idle for five days since the initial breakdown and also the nature of the initial breakdown last week is making me think something else could be at play.
Thoughts would be appreciated.
Thanks in advance
Have you tried charging the battery up? If you are making frequent small trips you could be slowly draining it over time and with no long trips never topping it back off.
Check your terminals are on tight and securely.
How old is the battery ?
Does your van have Start/Stop?
What battery is it?
Many thanks for your reply. Yes I’ve tried a charger on it yesterday. It went to 90%. Have run the engine for 10-15 minutes this morning with all the accessories on at 2500rpm and the tester was still showing 90% so hopefully the charge was the issue. Thanks again for your advice 🙏
Ignore the percentages, they are meaningless. Use the voltages.
How old is the van? Does it have stop/start? How old is the battery? What battery is it (make and type)?
