If it's a light knock/rattle, it's likely to be your drop links. I heard for Bilsteins you should ideally fit a set of longer drop links, as the mounting brackets are in the wrong place.
Assuming they're right, it might be play in the drop link ball joint - you should be able to jack the van up and feel any movement (or see if the fastening bolt if tight enough)
