Auto Electric Window
BennyBoy
Mountain Biker
Anyone had an issue with the drivers window one click open / close failing?
I was wondering if it was a possibility to switch the function on / off as the window works fine if I hold the switch.
Passengers window still functions fine and its not the end of the world just a bit annoying
Have you disconnected the battery? If so its lost its limits. Just put it fully down and keep hold of the switch for a few seconds then fully up doing the same. should be ok then.
Well that worked a treat all fixed thanks Alan!!
