AT wheels with Bilstein Coil Overs
Tazza
NEWBIE HERE..
I've nearly bought a Van with with Bilstein Coil Overs fitted.. I like the look of all terrain wheels tho.. can I use the AT wheels with Bilstein Coil Overs ?
Provided the offset is appropriate and doesnt cause any fouling, yes.
Yes if you like the look.
Also, the height can be raised if you want it a bit higher. I think bilstein are usually about a 30-70mm drop from standard depending on the setup
Have a look through this thread and then think about what height you’re running at. How to tell? Measure the edge of the arch to the centre of the hub, standard height is around 460mm.
