What, where are you using to meter the 15v?.
What battery setting have you got the ctek set to? (AGM?)
As per @Spaghetti BM2 battery monitor chart, 14.9v is a full charge rate indicating a low AGM leisure battery........ which will drop.down to a lower voltage 13.6v is as the leisure battery charge rises....
Yes really good customer service. Everything is as it should be now yaaaayThat’s good customer service from CTEK.
The temperature compensated charging is via the little sensor that is stuck by the +ve terminal of the leisure battery.
It was the leisure battery showing 15v but saying that I don’t actually now what the starter battery was reading I should have checked15v is normal across the starter AGM battery when Regen braking and decelerating . .
more info . . . .
Stop/start...regen...smart Alternator... Dc-dc Charger For Leisure Battery Or Not?
So With all the talk regarding the Bluemotion thing and regen breaking and leisure batteries our T6 has finally arrived. The first thing we done was to checkout the factory fitted setup,...... Stop/start=check, Regen Braking=check, AGM starter battery=check leisure battery under passenger...www.t6forum.com
Mine must have been in Desulphation glad to everything worked out phewww lol
