Anyone have any idea where the fuse is located on a 2011 t5.1 for the interior lights?
Rich Green
Electrician
Anyone have any idea where the fuse is located on a 2011 t5.1 for the interior lights? Also I have 3 cables. Which go to 1/2/3 on the original light. Does anyone know which is switched live and earth?? Thanks
Sorted. The fuse is the 7.5amp one in centre of fuse box. The pin outs are as follows.
pin 1 permanently live.
pin 2 ground.
pin 3 switched live.
pin 2 ground.
That’s not right. There is no switched live.
wire colours are-
brown - permanent -ve
brown/red - switched -ve
red/black - timed +ve - this is switched off by the BCM after around 20 minutes.
My tester wouldn’t give me any readings on the cables I assumed a duff tester. I connected mine to the connections I mentioned above and all works fine ¯\_(ツ)_/¯
wire colours are-
I connected them to this configuration in the end.
