Amorak Wheel bolts
jaymart
Hello , Fitting a set of amorak alloys to my van 17 inch previously had wolfrace 17 inch does anyone know if i can use the same wheel bolts or do i need a dedicated set ?
many thanks
Alloy and steel wheel bolts are different.....you'll need these
thanks they are both alloys the wolfrace have 60 degree wheel bolts would they be ok for the amorak alloys ?
Sorry read it as steels 🤦‍♂️.......your bolts should be fine
No, you CAN NOT use the bolts that have a conical 60deg taper.
You will need OEM VW radius bolts for Amarok wheels.
The above advice is incorrect. VW wheels, both alloy and steel use the SAME radius bolts. Aftermarket wheels use a conical bolt, which is what you say you have already. You need new bolts.
