Airbag fault
GingerDub
So I’ve installed a new head unit today and had to take side panel off and disconnect the passenger airbag switch. I also did this at the weekend except today it’s now showing an airbag fault on the dash.
Any ideas and is it a VCDS fix?
The head unit I installed is now also switching on when unlocking the van and will not power down when locking if I do not engage the ignition
Any ideas for this one?
Alpine Halo9 with Alpine fitting kit so pretty much plug and play.
From memory the air bag control switch connector ( is it the spring loaded release type ) if so can look connected but aren’t, disconnect and retry if you haven’t already
Cant help with the head unit but I had the exact same issue when I removed the side panel. Unfortunately, to clear the light off the dash is VCDS or other.
