Hi All.
Sorry for longish post.
Currently waiting for my Nutexa Friction Linings (NFL) 340 mm uprated disc kit for 17 “ Wheels to arrive. Spoke to Janet at Nutexa today and hopefully getting shipped next week.
Anyhow, quick query on the back plate.
Mines a T6.1 with 304 mm OEM. The NFL kit comes with ‘all I need’ ie carrier, hoses, disc, pads blah blah. But….. I’m stumped on the Back Plate.
It appears to me, from what I can glean from my local VW parts desk, and the www. that the O/D of the 304 and 340 mm Disc plate is identical at 355 mm. (Sure enough measured mine and O/D 355 mm)
I have two part numbers to reference:
7E0615311A & 7E0615312A which I obtained off this forum after a search for 340 mm back plate.
7E0615311B & ………..312B which, I obtained from VW as they are fitted to mine, so obviously for a 304 mm disc.
When I spoke to VW to get some ‘technical info’ on the 340 mm back plate (quoting number ….311A & 312A) I wanted to order they basically would not tell me much as “it’s not on your van, so we would be unwilling to give you information to allow you to fit it”
well thanks for that !!
My local indie parts supplier has conflicting info on the above parts and what size fits what. So they can’t help either (although they were very good at trying TBF).
So question.
1. As the O/D of both is the same, is it just the mounting points that are different for the two variants. (What’s the difference).
2. Has anyone fitted a NFL uprated kit on their OEM 304 mm van and can tell me if I actually need the back plate from a 340 mm van? (I appreciate that if I was fitting a set of T32 OEM brakes, yes I’d need it to match the VW caliper,).
3. Are the part numbers above correct or have I been an arse
Unfortunately as (obviously) my discs and wheels are still on, as van in use I can’t see exactly where back plate bolts to (hub or caliper) otherwise I’d probably be able to answer my own Q2.
Did try and ask NFL but Russ was unavailable, and was hoping to get plates ordered ( if needed ???) prior to kit arriving. If not I’ll just have to offer it up when I get it, and go from there.
Thanks in advance
So question.
Thanks in advance
