Advice needed on ODIS-E
stoem
I'm not sure if anyone can help with this but I'm trying to connect to my 2016 T6 Caravelle via ODIS-S and VAS 6154 dongle.
Everything seems fine in regards to connecting (device test works) and voltage is shown as well as ignition status.
Automatic identification of vehicle fails. If I enter VIN I can proceed but any access to read information on any installed component fails with this or a similar error.
Any advice appreciated. Failing that is there anyone in the Leicester/Market Harborough area with VCDS who could flash the Webasto heater firmware for me (I have the file)?
Thanks.
More info..
I assume you have installed your own aux heater and enabled it in the gateway list?
I have the Webasto engine heater which can be turned into a stationary heater with a firmware upgrade (plus a sender, receiver and wiring kit which I have).
Hope that helps.
I've just found a help article that states that the VCX Manager software cannot be open at the same time as ODIS. I will test that advice tomorrow.
Can gateway can’t talk to it anymore, does it have power?
Okay so it’s a communication block.
The VAS device has power and appears connected. Maybe the VCX Manager software is to blame, I think it was open when I used ODIS. I will try it again tomorrow.
More testing, still no joy. VX Manager shows device connected but ODIS keeps complaining that ‘device disconnected’.
I’m running Win7 in a virtual machine, will try a fresh Win laptop next.
Virtual machines are dodgy in this context.
I would always use actual computer and for this application Windows 7 is the best.
