Additional USB charger help
lukethompson86
T6.1 owner and all round VW enthusiast
Hi all
So we have a t6.1 which has had some conversion work done over the last couple of years.
I’d really like to add another couple of additional usb charging points. Mainly on the other side of the van.
Running the cables is not an issue as the route is easy , however I just wanted to check I’m headed down the right route , we have the typical leisure battery under the seat with a split charge system and this litle what I assume it a mini fuse board in one of the cupboards.
Am I right in saying that I simply wite the posi and negi into this board along with a fuse to match out the back of the usb charger ?
Pics of what I have an what I was looking at ,
Thanks all
Yep, wire it into that fusebox with a minimum 1mm cable on a 5 amp fuse and you are good to go
Positive to one of the empty fuse locations, negative to the common bus bar at the bottom of the unit and pop a fuse in. I have the same USB socket you linked and it works really well.
