Adding Multi Function Buttons.
NickyBrown08
Hi all.
Can you add Multi Function Buttons to a steering wheel without buying a complete new wheel.
I have seen the Buttons and fascia on eBay and a wiring loom which I am guessing you
will need. And then getting it coded and what not.
Added photos of current wheel and Buttons.
All help welcome.
Thank you
This can be a bit of a minefield
It looks as though your wheel will take the buttons
But if your van is a EURO6 those buttons won’t work. They might if it’s a EURO5.
They need to be from a T6 to work properly and light up red same as your dash.
The buttons you need have the CNL button on the left.
You will need to add wiring and then code them in.
It’s possible to activate cruise control on your van if it never came out the factory with it by adding a wire into the ebox below your battery.
There’s a few threads on how to do this. Have a search.
