Hi all,
I have found the solution to this but it was really puzzling me and couldn't find the answer on here so I post partly in the hope it helps someone else, and partly because I'd love to know why on earth this happens in the first place...
So, I swapped my passenger double to a single captain seat (no issue there) and subsequently changed the drivers seat as well so I had a matching pair. When I did that, I got two errors (both code U1123 00 009) which were Airbag and ACC short to ground faults. If I cleared them they just came back.
Long story short, it turns out this is because the seatbelt buckle is different in manual and DSG vans. Autos buckle part codes start with 7LA and manuals are 7HO.
The buckles, and their electrical connectors, physically fit and appear to work but bring on the fault code. Unbolting the buckle and swapping it with the one from the DSG seat solved the issue.
So, hopefully that helps if anyone else is in the same position - but why on earth do manual and DSG vans have different seat buckles?!
