Sold Absolut5 Audio Loom
Tim Sparkes
Absolut5 audio loom that will allow rear speaker and amplifier installation. Loom is still in the van at the moment but can be removed tomorrow and be in the post next week.
£45 including postage.
Paypal friends and family.
Tim.
line level output on the rear fader from the radio?
then speaker input for rears?
To Amp up rears? - how did it work before?
just looking at these colours . .
Bit of a hijack of thread......but
If I was trying to use the existing wiring from the head unit to remotely turn on power to the amp do I use pin 5 on block A or pin 6 on block C.
Also if you were putting in an active/powered line out for amp LEDs would it use pin 3&6 on block C
The pic i posted above is not T6 specific, i was just using it as an example of speaker colour schemes.
there is no +12v remote or line level outputs from the navi.
you need a hi-level to RCA converter, that generates a +12v Remote signal . . .
like above . . . . . This is cable made for the T6 loom,
which is giving you low level RCA & Remote.
i was just asking which way round it was configured ie front/rear.
Support our trade Members :
(@Absolut5) absolute new | VW T5/T6 Specialists
other examples are here: 2chnl & 4chnl
Or you could buy this one which has everything you need.
That loom give rca output with switch feed, keeps the front speakers working, the purple and green wires are for rear speakers,
Thrashers can be supplied in any configuration
I understand what your saying....but not everyone can just throw money into their van. I'm far from being tight but I do like to do things myself.
If i can do something myself for £15 and an hour of my time rather than paying £40-£50 for the same thing then I'd normally do it the cheaper option........for one the self satisfaction is good and two it expands and tests the brains a bit out with normal every day routine.
Just my opinion and the way i am.
Hi,
Is this still available?
Can you tell me if the RCA output is low pass or will it need a filter adding and if the radio will need coding?
Still available. Sure RCA is a full output not just low pass. @Absolut5 can you clarify?
Surely the amp you'd be using would have a LPF?
Only coding required would be for the rear speakers should you want to utilise the output.
Hi,
The lead give a stereo rca output, low pass is done at the amp, or from a aftermarket headunit
The lead also has front and rear speaker pass through, so ideal for 4 speakers from the headunit plus a sub
