Hi all,
Used set of LV2s just taken off my van. Good condition with no repaired cracks, some little stone chips here and there but nothing I noticed when on the van, although one mark has been touched in (see pics).
Spec -
The two front tyres I had were worn so removed and disposed, the other two have 5mm of tread and both needed a puncture repair. Told the fitters not to mount them back on in case the new owner wants to go with a different tyre setup. I was running 265/40/20 all round, but could go with a 245/45/20 front and the 265s on the rear if you were running on the low side.
Having gone with cheap tyres before can say these Hankook's ride and drive far better so were worth the £220 cost each and they are load rated to 104 so suitable all the way up to, and including, T32. 265/40 is also a far better size than the cheap, oversized 275/40s Leighton like to fit.
I'm based just off junction 13 of the M5, Gl10 3AA. Will be collection only as I've had some ridiculous quotes for sending stuff these days.
Looking for £600 for the wheels, tyres and bolts (including locking bolts).
Spec -
- 4x LV-2® Alloy Wheelset - 8.5x20" Front / 10x20" Rear
- 5x120 PCD
- ET45 Front / ET38 Rear
- Load rate of 860kg per wheel
- Fitting Kit with locking wheel nut set included
