It was specced out from VW and has a one piece grill that was painted black by VW on order, but I want to fit the DLRs and fog lights, the lower grill for those is also one piece so not sure which way to go with this ? Also the bumpers were colour coded by VWYou can go to your main dealer to get one or we can supply one for you, i think they are in the region of £40 but if you have a one piece grille i assume it is a startline so not sure how that would fit ??
If its not a start line (ie coloured bumpers) then you dont need one as they are in three separate pieces already and the DRLs just replace two of those pieces
Hi AgainIf I'm reading right.... the grill you have is moulded into the bumper. Is it a startline or trend line?
If you want to fit drl and the removable grill you will have to get a new front bumper.
The grill sides are more angular on the removable grill and square on the moulded one.
If I'm reading it correctly.......
If i take some pictures up tomorrow, can you clarify that its deffinatly a one piece bumper ?I see. You won't be able to fit the Drl grill etc as the startline is all one mould.
You need a trendline or Highline front bumper with the removable grills.
So am i getting this right ? I cant remove the lower grill from the bumper and also the bottom fog light surround cant be removed ?Yep that's one piece. Even the upper grill between the lights is moulded one piece to the bumper.
