Private Sale!
Base Van Spec:
Note: Conversion was done in late 2023 and has had over £29,000 spent on it with recent battery upgrades.
INSULATION PACKAGE:
CBE PC210 Power Management System:
All cabinetry is CNC cut from High-Pressure Laminate Furniture Board. and constructed using cam-locks (not connector blocks).
RIB ALTAIR:
PRICE = £39,999 ONO (NO VAT)
Serious Buyers Only!
[email protected]
Base Van Spec:
- 150 DSG
- T32 LWB
- Factory Kombi (before conversion)
- 43,000 miles
- Full Service History
- MOTd expires Oct 2026
- 2 Keys
- Black Paintwork
- Factory Satnav Head Unit
- Passenger Captains chair
- Tailgate (window & washwipe)
- Reverse Camera
- Front Factory Cab Carpet
- Front & Rear Parking Sensors
- 20Inch Alloys
- Bumper Protector Tailgate version in Black
INSULATION PACKAGE:
- 7mm Dodo thermo-liner closed cell foam
- Dacron polyester Insulation
- New CNC machined interior ply panels with detailing strips & hidden panel clips
- High quality 4-way stretch lining material in charcoal
- 1-piece 12mm exterior ply floor
- Altro Walkway Commercial grade lino
- 5mm Closed Cell Insulation
- All Floors are bonded in “Not Screwed in”
- Cool white LED strip lights (switched)
- CBE Lighting Dimmer
- Digital Control Panel
- 230v Hook-Up (Under Bonnet)
- CBE Battery Charger
- CBE Consumer Unit
- CBE 12v Fuse Box
- 135ah Lithium Leisure Battery
- CBE 12v Socket (X1)
- CBE USB Socket (X1)
- CBE 230v Socket (x2)
- CBE Fresh Water Indicator gauge
- x1 Front Cab Curtain (deluxe black-out)
- x1 N/S & O/S Front Side Vanshades blind
- x1 N/S Rear 1/4 vanshades blind
- x1 Tailgate Vanshades blind
- Front cooking section
- Rear Wardrobe Inc. (Tambour Roller Door – LWB x2)
- x2 Opening Drawers & x1 opening door to kickboard (front) to 112cm RIB Altair frame
- Solid fixed Kickboard (rear) to 112cm RIB Altair frame
- Seat Base cover(s) in matching furniture board
- Concealed soft-close kitchen hinges
- Flush fitting doors
- Aluminium corner profile used throughout
- Full Width Rear overhead locker with recessed strip lighting (switched)
- Full Splash back with integrated overhead shelf with recessed strip lighting (switched)
- 8Loc sliding door table trimmed in charcoal lining material
- Fire Extinguisher
RIB ALTAIR:
- 112cm RIB ALTAIR (2-seater) custom made by SCOPEMA in France (fully tested and approved bed)
- Trimmed in genuine VW fabric
- Integrated Headrests & Integrated Seat Belts
- 65cm rear cushion (6ft0cm bed)
- Fixed Frame
- Space to store a Thetford 335 Porta-loo
- 49lt Webasto Cruise front loading fridge with flush fitting surround
- Dometic 9722 Double Burner/Sink (Inc. tap)
- 29lt underbody fresh water tank (*not suitable for 4-motion vans)
- Fixed shurflo water pump
- Internal water filler point
- Waste water outlet (under van)
- Vented safety locker suitable for Camping Gaz (904 & 907) Inc. regulator, pigtail, bottle adaptor bottle strap etc)
- CBE LPG Detector
- Gas Safety Check by independent GAS SAFE engineer (Gas Safe Certificate Issued)
- REIMO Easy Fit Roof (Bonded System)
- REIMO Deluxe Pocket Sprung Roof Bed Inc Memory Foam Matrass
- Blackvue (Front & Rear) Dash camera with Parkmode feature wired into leisure battery
- Additional USB socket in roof bed area
- Webasto Airtop 2000 heater externally mounted (Inc upgraded digital timer & CBE "CO" Monitor)
- LWB Reimo Multi-Rail (For securing drive away awning)
- Sound Proofing - Strip coverage to side panels and inside rear doors
- Bulfinch Gas BBQ Point
- Internal Pop out coat hooks
- Passenger Swivel Base
- Towbar
- Speaker Install - (Pioneer rear speakers mounted in rear overhead looker and coded via Vagcom to factory head unit for rear speaker fade.
- New Vehicle Battery (Replaced May 2026)
- New 135ah LITHIUM leisure battery (Replaced May 2026)
- Recent Habitation check by Northshore Custom Conversions (May 2026)
- Recent Health Check by Pulmun VW Garage (May 2026)
[email protected]
