Scottishstu
Hi all,
I’ve just picked up a 2018 T6 Startline and found this under the passenger seat (photo attached).
From what I can tell it looks like a factory auxiliary battery setup, but it doesn’t seem to have the usual visible fuse board / split charge setup that I’ve seen in other posts.
I’m planning a camper conversion and want to install:
Main questions:
Ideally I’d like to reuse as much as makes sense, but also don’t want to compromise the setup if I’m going lithium + Victron.
Happy to pull the seat and get more photos of wiring/routing if that helps.
- Lithium leisure battery
- Victron Orion-Tr Smart DC-DC Charger
- 240V hookup with charger
Main questions:
- Is this actually a live factory aux battery setup or just pre-wiring?
- Can I reuse the existing cabling (looks like there’s a 100A fuse on the feed)?
- Cable looks around 10mm² — would you reuse it or run new 16mm² from the starter battery for the Victron?
- Where would the factory split charge/relay normally be on these?
- Am I better off stripping it back and starting fresh, or building onto what’s there?
