2017 T6 Intermittent short in Ignition rail
Steveg69
Hi all I have a 2017 T6 which has developed an intermittent short causing the main fuse link 40A to ignition to blow
History
I've had a previous intermittent fault for around 4 weeks causing 10A SC30 to blow
This powers the mirrors, Oil sender & Rear park assist, fuse will blow replace it and works fine for a day and randomly blows again.
Just recently on Wednesday last week waiting at traffic light, Go to take off move 2 feet and Main fuse to ignition blows loosing all power to dash
Hazards and radio still works its as if (as others have mentioned removed key from ignition)
Tilt tray to auto electrician car is now in pieces and they can not find what has caused main fuse to blow
I read in here some have hade issues with BCM has anyone else had similar issues?
Faulty ignition barrel maybe ? although it wasn't touched when fuse blew
Thanks for your time
Steve in Australia
Hi Steve from Australia.
Good-ay mate
Take a look here.
T6 - T6 Fuse Layout SC,SD,SF (NON-CALI)
Sc30 could potentially power a lot more stuff, depending on what's fitted on the van.
Can you post some pics of the blown fuses?
How they have blown will give you an idea on the type of short. (If imaginev it's a allow blow where the wire has got hot and deformed over a longer time)
It's imagine it a wire that's rubbed through somewhere. An vibration is causing the wire to make the short.
This could be tricky to find.
But a good multimeter and a wiggle test should eventually find it.
You're guy will need to check the wire diagram to follow the feed around the van to find the fault.
Got some pics of the van?
Has it a rear conversion?
Good-ay mate
Take a look here.
Thanks for the reply I don't have the fuses anymore unfortunately Im not so worried about Fuse 30 its the Main ignition one that's the problem SC38
No conversion just standard nothing added other then a small fridge but it is cabled direct to battery car is standard
Hi , Pete from Australia.
I have just had a Horizon elevating roof fitted to my 2019 SWB Multivan which was a great mod as we use for camping and everyday drive.
Since conversion fuse 30 (10A mini fuse) is blowing when ignition turned on. Doesn't blow when just on accessories.
Causes aircon to lose cold air, oil sensor alarm , electric mirror fail, park assist fail, park sensor fail.
Conversion auto electrician having trouble locating fault and is assuming wire rubbing somewhere causing s/c but at this stage is struggling to locate.
May have to rip out new (conversion) hood lining.
Has anyone experienced similar or have any suggestions ?
Have 2 week holiday planned using van so getting it back from convertor and will return for more diagnosis.........
