After some help please…….
I’ve ran Goodyear Eagle F1’s asymmetrics in 275 35 20’s on my 6.1 California (lowered 70mm on coliovers) for 3 years and 18k miles and it’s time to replace them. It would appear that Goodyear only make them as runflats in that size now so I need an alternative.
Keen to stick with F1’s as they have lasted really well, I’m thinking of going 265 40 20 now.
Always liked the look of the 275 as they give a square profile and the speedo is spot on, negatives are the fronts rub a little on the inner arch (ET45 on full lock) and the tyre is quite close the wider Cali sliding door. After looking at willtheyfit the 265 appears to be taller and narrower so I could fix the inner arch issue and I’ll have more clearance to the door.
I think Bognor now recommends 265, they fitted the 275’s for me and I wonder if they switched due to Goodyear stopping making 275 in non run flat?
Can anyone share a pic of a 265 40, I’m assuming even though they are narrower the 40 profile makes them look a bit more chunky on the rim, i don’t want it to look too rounded/stretched if you know what I mean.
Thanks in advance.
Thanks in advance.
