12v usb panel socket replacement
goldeneye243
Hello all,
Does anyone know where I can get a replacement usb socket? Mine seems broken - doesn't charge and the the fuse blows when I replace it
Or ideally a USB-C pd socket if that exists?
As @Pete C said it maybe CBE but it could be a CLine as well. As I understand it, CBE and CLine are two different firms but their stuff is mostly interchangeable. He's also right about them being widely available on eBay or Amazon. I actually replaced a single USB socket a while ago with a twin 1A /2.1A CBE -it came with a rubber cover which IMO is essential as it's also got a LED power indicator which is very bright. In case you don't know, the silver surround will just unclip to expose a supporting frame probably fixed down by two screws - take that off and the socket will come out.
