12v & 240v controllers
JDTech
Looking for ideas for what systems people are using to control the electrics on their T6's
I will be using my 300w solar panels, 2x 220ah batteries as I will be off grid quite alot, but i also want to be plugged in a some point and probably power a coffee machine, Hair straighteners etc.
I have a 1000w / 2000w peak inverter but know this wont power those things.
So i know at some point I need to bypass the 12v from my sockets and be getting 240v.
I did look at the Ctek 250se but don't know if this is right for me as will only charge up to 250ah batterys.
Anyone shed any light ??
300w of solar you will need a decent MPPT controller. (To much for a ctek)
You will need a dc-dc charger, possibly check. But if you have 440ah battery bank 25A charge rate might be a bit slow, look at 40A redarc or 50A renogy.
If using EHU, run separate 240v sockets, or get a auto change over in your CU.
Have a look over here for some info.....
