Webasto doesn't work - Caravelle T6
Jey
Hi!
Now, it's mine Webasto on my car who doesn't work any more (few weeks ago, it was for a friend).
I have a VW Caravelle T6 since October 2016.
298 500Km today.
I use the webasto many times per day, every day during the winter, since 7 years.
I never had any problem, and I never service it or fix or change any part.
Since 2 weeks, it stop alone before the end of the timer.
This week it's VERY cold on Lapland (-30 / -38°c).
Since yesterday, the webasto doesn't want to work. It stop after few seconds (sometimes, little more).
It's smelling strong (probably the diesel not fully/well burned).
We have a specific diesel here, working under -40°c.
Please, do you have any idea?
Please find the VCDS log
Wednesday,03,January,2024,19:13:53:11489
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZHH........... License Plate: xxx
Mileage: 298490km-185473mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 18 19 22 25 5F 61 69 6E 0B
VIN: WV2ZZZ7HZHH019780 Mileage: 298490km-185473miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6E-Ctrl Head Roof -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KK HW: 04L 907 445
Component: R4 2.0l TDI H02 6187
Revision: 23002001
Coding: 0019401CC35601090000
Shop #: WSC 16179 004 1048576
ASAM Dataset: EV_ECM20TDI03004L906056KK 004015
ROD: EV_ECM20TDI03004L906056JT.rod
VCID: 005A88B2EA81CD1A2F3-8054
VINID: 9E60AAAAA1D8A986000491C8001E1DE04F
1 Fault Found:
15918 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [10101111] - Electrical Fault
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 298391 km
Date: 2085.01.05
Time: 23:33:04
Engine RPM: 826.25 /min
Normed load value: 27.8 %
Vehicle speed: 0 km/h
Coolant temperature: 25 °C
Intake air temperature: 0 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.234 V
Unlearning counter according OBD: 40
Pre-glow time: 2.5 s
Glow status: Post-heat
Outside temperature sensor 1: B1: raw value: -16.5 °C
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 41656000000431
Coding: 347EC098256386872C7C037EA482615378F500
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FD84B4ED7FF72E2169-806A
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 11061613471753
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F64A9075BBEA5DF-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 AB HW: 7E0 907 040 AB
Component: ClimatronicT5 H04 0510
Revision: 00001K04
Coding: 0000000103
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis_VN75.rod
VCID: 6390A73E1BD77602521-8036
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serial number: BHB-0011107170015197
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 174161295
Coding: A0F8793A0A61341293284F746CEB86F40F94690F60CC6960320400A30840
Shop #: WSC 02737 022 574517
VCID: 2A0E0A1A3CFDE74A517-807E
Subsystem 1 - Part No SW: 7E0 959 801 N HW: 7E0 959 801 N Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU016061661686181
Coding: 0400A1
Subsystem 2 - Part No SW: 7E0 959 802 N HW: 7E0 959 802 N Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU016061661687720
Coding: 1400A1
Subsystem 3 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 5 - Part No: 7E1 951 171
Coding: 000000
Subsystem 6 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A
Component: E221__MFL-DC1 H02 0103
Serial number: 29160001208040126242
Coding: B4FFFF
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 298374 km
Time Indication: 0
Date: 2018.05.25
Time: 16:39:09
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261613101314
Coding: 31800C
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BCDD76D12BD492D0D-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0210
Serial number: 17061604402990 Dataset Number: 7E0114v____ 0009
Coding: 00004800FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 36362E6AF8C5B3AAC5F-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 H HW: 7E0 959 655 H
Component: VW10Airbag01R H08 0018
Revision: -------- Serial number: 003V4000RGYT Dataset Number: 7E0003V____ 0908
Coding: 000000000000000000000000000000003152
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3B203F5EC3E76EC23A1-806E
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB40533V6TC38I1
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3505ZRB40513V6TCG83W
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 870 S HW: 7E0 920 870 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 150F010400
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 392C2556C9DB5CD228D-806C
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 272 B
Component: STH-T5GP2 003 0009
Coding: 5001
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B000F1E3387FE42AA1-807E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000057769
3 Faults Found:
0045 - Combustion Air Blower
B1384 07 [00001000] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 236
Mileage: 298374 km
Date: 2024.01.02
Time: 16:46:34
Parking heater: operating condition: System malfunction
71
Coolant temperature of parking heater: 50 °C
Coolant temperature: 50 °C
Engine running status: not detected
Fuel level: 80 l
Heating performance: 0 W
0021 - Combustion Air Blower
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 298391 km
Date: 2024.01.02
Time: 20:45:51
Parking heater: operating condition: After-run - burnout
71
Coolant temperature of parking heater: 63 °C
Coolant temperature: 58 °C
Fuel level: 80 l
0137 - Combustion Air Blower
B1384 15 [00001000] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 236
Mileage: 298377 km
Date: 2024.01.02
Time: 19:51:22
71
Coolant temperature of parking heater: 64 °C
Coolant temperature: 63 °C
Engine running status: detected
Fuel level: 80 l
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042205
VCID: 688AB012E271155A873-803C
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serial number: HA1-00023.05.16 Dataset Number: v1260x015G0 0000
Coding: 0505
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 54F274E24E7981BADBB-8000
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8ECA1AFCFD274A917-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 G HW: 5K7 035 200 G
Component: MU-S-D-ER H30 0367
Serial number: VWZAZ2S5147971 Dataset Number: V03935243TT 0001
Coding: 06570000BE00000011111101008808001F0100D40020010003
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VN75.rod
VCID: 280AF0122271D55A473-807C
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 330B1A73
Shop #: WSC 80093 222 69422
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001606170048
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000408094162
Coding: 410D000103000000
Shop #: WSC 02739 790 00000
VCID: 323E127A142DAF8AE97-8066
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185
Revision: 10100011 Serial number: 435550
Coding: 000103
Shop #: WSC 02759 790 00000
VCID: 35342966E543B8B2CC5-8060
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 236
Mileage: 298399 km
Time Indication: 0
Date: 2024.01.03
Time: 07:50:13
End----------(Elapsed Time: 01:56, VBatt start/end: 13.9V/14.0V)-----------
Reactions: mmi
That suggests a fault with one of the fans in the heater (or the cabling to it) ?
Also, you are right on the limit for water heaters -
Max. ambient temperature:
Heater:
- Operation - Storage
-40 to + 50 °C -40 to + 80 °C
and also air heaters:
Permissible ambient temperature:
Heater: - Operation -40 to + 40 °C
- Storage -40 to + 85 °C
Fuel pump: - Operation - Storage
-40 to + 40 °C -40 to + 85 °C
-40 to + 20 °C (petrol), -40 to + 30 °C (diesel), -40 to + 85 °C
Whichever heater you are referring to - it would help to know!
For OP to verify of course but I’m pretty sure it’s a water heater and most likely 5kW Thermo Top Evo - very common factory option in Finland. Scan HW and SW numbers match mine.
Code:
   Coding: 5001
   Shop #: WSC 12345 123 61029
   VCID: 2B086FC6C3878AD28A9-807F
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Most likely the cause is some grit the heater has inhaled which is jamming the blower. You do have all the bottom cowlings/fairings in place?
Could it be something as simple as sucked powdery snow which has melted and now frozen - preventing the blower to run freely??
VCDS has a test to run the combustion air blower - makes quite distinctive noise.
VCDS > Select > 18-Aux.Heat > Output tests > IDE06615-Combustion Air Blower
If it doesn't run could lightly tap the heater to try to free the blower.
Heater:
I had the problem far from -40, maybe +/- -25 when it became to stop alone after a while.
It's a "French" caravelle (not a nordic version), but I made lot of modifications on the car (like insulation inside the cabin)
I have a Thermo Top Evo 5 kW / water / diesel / max 2.5 bars
Code:
   Coding: 5001
exactly the same sticker.
Ok, I will try to look this afternoon. Thanks !
We had -45°c last night at my place, the coldest temperature in Europe since years...
Last question (I hope), do you know a good tutorial to access to, remove and open the webasto to service it myself ?
The combustion air blower is running at +/- 9500 tr/m
The glow plug seems to work.
The metering pump is going 7hz
Now I will try to look under.
Thanks for the PDF, I look now !
I see nothing from under, the plastic cover is in place.
I started the webasto.
I feel everything is starting like normal (listening all noises).
I saw that the exhaust pipe if not stuck, I saw a lot of smoke (too much - bad ignition ?), the fan was going faster and faster, I heard "clic clic clic clic" like normal, then still lot of smoke, then no smoke anymore then the webasto stopped, the fan was going slow.
I tried to started it again 30 second after and it auto-stopped after 1 second.
I can't warmup the cabin and the engine at the same time when driving, it's too cold :(
I learned few things in this videos.
But I can't lift the car and access quickly to the webasto (I use the car always during the windows for my job).
2 days ago, I checked on Volkswagen Transporter Kombi (2016 - 2017) - fan. auxiliary heater. > VAG ETKA Online > Nemiga.com
But I found a different part number : 7E0 963 319
To me all those look like the air heater (=not yours).
Since few years, I have on my to do list, to buy a new glow plug for the webasto. I didn't do it yet...
But few years ago I looked for the part number.
I found this : 5Q0 898 065
That's correct for the coolant heater you have.
Ok for the spart part, thanks !
I just tried again to start it.
This time, it started. It was not smoke but steam. So, good... I heard the cabin air blower working, just... 1 minute.
Then everything stopped.
I started successfully 2 times more, each time during a longer period.
It seems it stops when I open and close the door of the car !
Now it refuses to start, I have the green LED of the remote flashing : long short - long short - long short (I look now on the net what it means).
What does the VCDS say?
My guess - heater is locked.
I was able to start it from inside the car, before to unlock (vcds answered "not running") then the remote worked again.
Thanks.
Do you have any idea why it stops by itself?
