Im prerunning some cables while I'm installing some other bits. Could you helpful chaps confirm the below is correct please. This is for my leisure battery.@Dellmassive
The inverter will only be used for powering laptop/screen when Im out and about 'working' I will run a totally seperate 3 way extension from the inveter so theres no physical link connection to the EHU (apart from the EHU is earthed to the ground under the passenger seat) (the EHU only gets used when the van is sat for long periods on the driveway to charge the leisure/starter battery the EHU does have a 4 way on it)Are you running the inverter to seperate sockets from the EHU sockets?
How is it /will it be wired up?
Got some pics?
Thanks MMI, it'll only be used to power a laptop or 2 and a screen at most.I would stick with a conservative choice of 30A fuse -
- Max continuous output power of the inverter is 300 W, thus on the feed side 330 W (taking into account the efficiency 90%). 30 Amp fuse allows 30 Amps "forever" which equals to 360 Watts.
- Peak power 700W to start-up LEDs, filament bulbs or electric tools shouldn't last very long. 30 Amp fuse will withstand 60 Amps at least 5 seconds which should be more than enough.
- Internal 80A fuse in the inverter is not replaceable.
PS. At the maximum I could go for 40A fuse if the load indeed would be continuous at inverters maximum capability.
