Wiring for T6 204bhp inverter
Has anyone put an inverter into the latest T6 204 ? its a highline kombi, i have just been informed that an expensive relay unit is probably required for approx £260.
I have a 2000w inverter and leisure battery ready to go, same setup required as i have in my trafic with solenoid and switch charger with jump start facilities but also a 12v winch to be connected to the leisure battery too.
Thanks!
You can use a Ctek D250 as the split charge unit as this is compatible with the regenerating alternator. Slightly less than £260, there s also a Sterling power unit available for less.
Mine goes in on Monday to have this done. Don't know what make they are fitting, but I do know it is the one for the intelligent alternator on the blue motion, and that's £250 inc VAT
Just looked at my quotation paperwork, and it is the Ctek Dual 250s that is being fitted to mine.
Just re-read your original post @Chris Hewitt and had missed the point about having a winch! Now that is a proper mans toy. None of this "what tyres should I have for winter or snow chains". Get a winch, find a big tree and drag yourself about on it. LOVE IT.
I once went orienteering with a mate in his hardcore off-roader, and it was all about winching yourself down slopes and up slopes and al over the place to be able to get close enough to the clipper to clip your card to show that you'd got to the check point (and there was no way of cheating as the card was attached to the dash). Never had so much fun in all my days. Wonder if I could do that in a T6???:rolleyes:
Winch installed but not where you'd think! It'll make the t6 multi purpose, all my stock and equipment can unload in one hit then a safe can be loaded with it! also have all the camping kit in one box on castors so it can be pulled in too and this also doubles as a bed for long trips combined with the folding bulkhead. Another reason for the winch is to pull our sea fishing boat up a slipway without getting the t6 anywhere near the water! It will certainly be handy to pull us out of trouble backwards should wr need it but hopefully the 4motion willl handle most camp spots!
Inverter installed! Pick her up on Monday morning but pic attached sent by Rob @ Autosound. Also done my reverse camera too!IMG_0420.jpg IMG_0396.jpg
