Drain it would be safest and make sure the hoses are empty too a little water in the tank alone shouldn't harm
Many thanks , how would I clean it .?You should be emptying it after you finished anyway, not good to leave water in a tank that long especially if you use it for drinking. You get slime in the tank. You should also clean it every so often
Having already bought some myself for this purpose I was going to suggest Milton fluid but I’ve since read that anything with a high chlorine content is bad for hot water systems and can corrode them. Apparently Aqua Sol is the thing to use.Many thanks , how would I clean it .?
We use milton Tablets and never had a problem since we had a caravan which is over ten years.Having already bought some myself for this purpose I was going to suggest Milton fluid but I’ve since read that anything with a high chlorine content is bad for hot water systems and can corrode them. Apparently Aqua Sol is the thing to use.
This was one of the posts that has made me question Milton (I have a hot water system fed from fresh water tank so don’t want to risk it). Dont use milton in your fresh water tank!We use milton Tablets and never had a problem since we had a caravan which is over ten years.
Yep we Ex Motorhomers know this to be a truism. Stay away from Milton for the Fresh water tank.This was one of the posts that has made me question Milton (I have a hot water system fed from fresh water tank so don’t want to risk it). Dont use milton in your fresh water tank!
Reading the link I posted above, I think the issue is with the chlorine corroding the steel and stainless steel in the hot water tanks/elements/tubes. As I said, I was all for using Milton and have a bottle ready but will not be doing so now.So why do people use it to sterilise Baby's bottles, if it is OK for them should be OK for us. I think the Motorhome people are a little OTT with that. If there was a problem with Milton Tablets they it would not be safe to used on a Baby's bottle would it.
Fact is we use them in the Aqua roll and the fire the stuff through the system followed by clean water. The tanks are emptied when we leave the caravan anyway so we never store water in it why would I want to pull more weight than I need to. Never had the problem with the old Cali as we never put water in the Tanks. Why you leave water in it when your not using is seems stupid as it goes stagnant
