Wind Deflector Coming Loose
Bobbysocks
Hi,
I have a rubber wind deflector in front of the pop top that is coming loose/peeling away.
As someone who knows absolutely nothing about such things what would people use to stick it back down? Gripfill?
Hi,
How long has the pop top been on, and what make is it.
My first suggestion would be to take it back to converter that did it and get them to replace it. If for whatever reason that is not possible use some thin 3m double sided tape, as that will undoubtedly be what was applied in the first place. It could have got some contaminant on it when first applied such as a greasy finger print which has caused it to lift.
Thanks very much.
It will still be under warranty but unfortunately the conversion is a good few hundred miles away, so its probably easier to do myself.
You are correct, it was originally double sided tape. I will have another go with that.
Thanks again
Rob
