Do you have adaptive cruise?Jut had the front and rear pads done today. Fronts worn 70% but the rears worn 90%. I thought that the front would have worn faster, am I wring to think this?
Ah, is that why my rears wear faster?!!Big brake set on the front? (T32 / 204 style)
That's interesting.....Do you have and use auto cruise control and/or an electronic parking brake? I understand ACC uses light rear braking to maintain distance and EPB drag when setting off increasing wear. My Passat uses rear pads faster than the fronts and it has ACC and EPB.
Hmmm, rear only braking sounds dangerousSuppose we can use vcds to data log a trip and prove the idea.
@mmi this sounds right up your street? Maybe a data logged trip with ACC on to see if the ABS control is rear only for distance regulation?
Are you sure that front and rear pads have been replaced at the same time prior to this replacement?Jut had the front and rear pads done today. Fronts worn 70% but the rears worn 90%. I thought that the front would have worn faster, am I wring to think this?
I use EPB for over 3 years now and my rear pads don't get worn quicker than front.Do you have and use auto cruise control and/or an electronic parking brake?
ACC "commands" ECU to accelerate and decelerate. When the rate of deceleration by the ECU is not sufficient, then ACC "commands" ABS to slow down.I understand ACC uses light rear braking to maintain distance and EPB drag when setting off increasing wear. My Passat uses rear pads faster than the fronts and it has ACC and EPB.
It’s very subtle on the Passat, just a gentle drag to maintain distance, anything more then it’s normal braking. At least I assume (and it feels like) rear only as there is no dive and I’ve read elsewhere about ACC using the rear. ESP will also apply individual brakes as it sees fit.Hmmm, rear only braking sounds dangerous
I use my ACC in the Golf a lot, almost all of the time. I love it. My front brakes wear out well before the rears. Certainly in the Golf it doesn’t seem to apply the rear more than the front. Mines a DSG so it can obviously change gear if it needs to but I doubt any manufacturer would use only rear brakes in these systems?Do you have and use auto cruise control and/or an electronic parking brake? I understand ACC uses light rear braking to maintain distance and EPB drag when setting off increasing wear. My Passat uses rear pads faster than the fronts and it has ACC and EPB.
We certainly do have that feature.Do you have adaptive cruise?
In answer to your first question, we have had the van from new and this is the first time the pads have been changed at 26,045 miles.Are you sure that front and rear pads have been replaced at the same time prior to this replacement?
Also were they of the same brand/make?
Even tough I constantly use EPB auto-release and auto-engage.
ABS braking is almost always done by all 4 wheels. There is only one exception, when the braking is initiated by the manual pull up of the EPB switch.
This is so-called Emergency Braking and then braking is performed via rear axle only(subject to EPB configuration & ABS compatibility).
Hahaha if only, this is a Motability van so nothing so exciting I am afraid.Big brake set on the front? (T32 / 204 style)
only the obvious like people have pointed out mate, we've got the ACC on our Golf and wear rate is normal. does rear disc feel hotter when you've finished a journey? possibly binding?I'd of said the obvious option is the brakes are binding either calipers not release properly or the handbrake mechanism is jammed. That's where I'd start before anything electronic.
@Nutexa Frictions any guidance?
