Which oil? 150PS diesel
EdH
Planning Officer
Hi all,
I am bit confused with the type of oil for my new conversion. It's 2020 T6.1 2L 150hp Tdi (Engine - CXHA). On collection of my new van from the convertors last week I was given 1L top up oil of 0W30 504/507 spec in a VW branded bottle. I was under impression that it would be 5W30 504/507 spec. I phoned a friend in TPS today and he confirmed that my van should be on 5W30 and the same is appearing on their website. Spoke to the VW dealership in Wrexham (Commercials) and then they said that it left the factory on 0W30 and that's what they would use if serviced by them.
I am well confused about two different answers from TPS and VW dealership. What's the benefit of using 0W30 over 5W30, both 504/507 spec. 0W30 is much more expensive than 5W30. Can I use 5W30 instead?
Thanks in advance.
Castrol Edge 5w30
Which is equivalent to Quantum 5w30 504/507, and which I can easily source from TPS. So it appears that my brand new van is filled with 0W30 (hence top-up 1L bottle which was given in the van). I hope you understand my confusion VW dealer sais one grade and TPS advises another grade (both 504/507). As it's a brand new van, which will definitely use more than 1L of oil (top-up) in the next 12 months and then for its 1st dealer service. Can I simply top it up with 5W30 which I got plenty having just done service on my Mk5 Golf? Or should I not mix viscosity?
As long as it meets vw507 it doesn't really matter.
Yes, it would meet 507 VW spec. Why is vw using 0W30 in the UK? Colder Nordic countries yes I would agree, but the UK is not that cold to warrant 0W30? Or am I missing something?
I had this reply from VW, yes all of you guys were correct, which I didn't doubt. I didn't understand the difference/benefits of using either grade.
Thank you for contacting Volkswagen Commercial Vehicles regarding the correct oil specification for the above vehicle.
I have liaised with our Technical Team who advise that we do not quote 0W-30/5W-30 generally, the oil has to meet VW 507 00 standard. This specification should be printed on the container of whatever brand of oil is your preferred choice.
Both 0W-30 and 5W-30 can be used, in order to help you make the right choice for your needs, I include some general information below:
Difference between 0W-30 and 5W-30
Motor oils come as Multigrade or Multi viscosity. They usually have two numbers in their label. You would normally find the numbers to be separated by a W; an example is 0W-30. The number or grading system was introduced by the Society of Automotive Engineers, SAE. The grading or number system helps to determine which oil grade is suitable for a particular temperature range.
The numbers are assigned to the oils based on the rate at which they flow at different temperatures, i.e., flow rate within a temperature range. The number could be 0,5,10, 20, 30…, 60. The number is a factor of the oil’s viscosity. The lower the grade or number, the thinner and less the viscosity of the oil.
The W in oil grade symbolizes Winter. A lower number which translates to less viscosity is much suitable for winter. 0W oil will flow up to a temperature of -30 degree Celsius while 5W will flow up to a temperature of -25 degree Celsius.
When Can Each Oil Be Used?
Determining the best scenario in which either 0W30 or 5W30 can be used depends on two factors. The first factor to be considered is Temperature while the second one is Viscosity. Most times, manufacturers will recommend the two oils ( 0W30 and 5W30) for you but choosing the best depends so much on the aforementioned factors. However, 0W30 can always be used in place of 0W50.
Concerning temperature, a quick one to always have in mind is that a standard engine needs oil that flows well under the current weather conditions. A 0W or 5W is a pointer to how easily each oil will flow in winter, ( W stands for winter). A 5W oil thickens more than a 0W ( 0W is thinner). So, in Winter, 0W-30 will be the most suitable oil to use.
Generally, in winter, when the temperature is much colder, the 0W-30 oil will work better and faster because it will easily warm up the moving parts and gliding surfaces of a car due to its lower viscosity. 5W-30 oil, on the other hand, is relatively thicker than the 0W-30 oil, and this makes it more suitable in a case of a relatively higher temperature.
So, for a cold weather, the 0W-30 motor oil is recommended while for the relatively warm weather, the 5W-30 motor oil is recommended.
Understanding Viscosity
Viscosity simply means opposition or resistance to flow. In much simpler terms, it can be referred to as the flowability of a substance.
When it comes to motor oils, the viscosity is denoted by the number before W. For example, in 5W-30, 5 is the viscosity number which is what determines the rate of flow of the oil at 0 degree Celsius. So, the lower the number, the lesser the viscosity and the lesser it thickens in the cold. With this, you will expect 0W-30 to thicken less in the cold than 5W-30.
A motor engine in a colder climate would get a lot of help from a 0W-30 motor oil than the 5W-30 motor oil. This is a factor of viscosity. The outside temperature also has a role to play in determining which viscosity is perfect for use. When the temperature is cold, the oil flows slowly, but when the temperature is hot, it will flow more quickly. For adequate and proper lubrication, you must always put the viscosity in relation to temperature into consideration.
Basically, motor oils are manufactured in different velocities to achieve effective lubrication in different climate conditions.
Fuel Economy
The kind of motor oil you choose can make a big difference on how much you save. The 0W-30 motor is renowned for its high capacity to improve fuel economy. The 5W-30 has a viscosity that is higher than the 0W-30, this can be clearly judged by the grade or number it carries. Oils are either thick or thin. Thick means the oil has a high viscosity while thin means the oil’s viscosity is low. It is same as the case of these two oils; the 5W-30 is thicker than the 0W-30 motor oil.
It’s the viscosity or “flowability” or thinness of any oil that determines its fuel economy improvement capacity. The 0W-30 is thinner or less viscous than the 5W-30 which makes it considered as better for saving more.
This is not to say 5W-30 does not increase the fuel economy, but it does lesser than 0W-30 motor oil. Compared to other high viscosity oils, the 5W-30 can improve the fuel economy. You can have 1 to 2 percent raise in fuel economy with 0W-30 motor oil.
Temperature Range
Generally, all lubricants have a temperature range in which they can operate. Increased velocity under lower temperature may be a restrictive condition for a motor oil to function effectively. A higher temperature and a lower velocity may cause a reduced thickness which may cause damage to the machine parts.
The suitable temperature range for 0W-30 motor oil is a flow up to -30 degree Celsius while that of 5W-30 is a flow up to -25 degree Celsius.
Had my 2019 T6 150 diesel in for service at VW last week and just noticed on the invoice they have used 0w30 engine oil.
Looking back at previous invoices from from a different VW dealer before I purchased the van the engine oil was 5w30.
What are peoples thoughts on this? Which is correct and what are other people using?
My T6 diesel was filled with 0w/30 at it's last service by VW Van Centre. I would say that its a bit quieter and slightly better fuel economy.
507 spec is the important bit. 0W30 or 5W30 is fine, as is mixing them when you top up.
0W30 works better for cold environments (-35 deg C) and will flow better in a cold engine so good for colder areas and/or short journeys. Its upper temperature range is the same as 5W30 (+35 deg C) so no loss of performance in higher temps. 5W30 is good to -30 deg C so ok for the UK too but maybe not quite as good for short journeys.
Either way, both are fine for the UK so go with whichever you want.
p.s. the quotes temps vary a few degrees depending on the source, but are always 5 deg difference at the lower end and the same at high end for 0W versus 5W.
Wow, that was a long winded answer from VW.
It seems the only advantage to the 5W30 is price. Temperature range, Fuel economy and noise level seem better with 0W30.
Have I understood this correctly?
Last VW service I had used 507 00 spec. My oil was changed last week by an independent and used Castrol Edge 5w 30, as this matched VW's 507 00 spec.
Further to the discussion on the grade of oil recommended for the T6.1 the label in the engine bay of my van states 0w30 C3 grade, so did a bit more digging on the differences between C2, C3 etc. and concluded that C3 is better for a harder working van.......but not easy to find in 0w30.
I warmer climates I am thinking a 5w30 C3 would be preferable to 0w30 C2. Obviously VW504.00/507.00. Thoughts?
Shell do one (Ultra ECT 0w30 c2/c3), but I prefer Mobil or Castrol.
Understanding HTHS and SAPS​
HTHS (high temperature high shear) is the viscosity of an engine oil at a temperature of 150°C (considered a high temperature in engine compartments) and a velocity gradient of 106*s-1 within a set measuring vessel. The HTHS value provides information about the fuel efficiency properties of an engine oil and the potential fuel savings that can be achieved with the oil.
An HTHS value is a measure of the engine oil viscosity under demanding driving conditions. Established limit values are designed to ensure that even in high-performance engines, the oils can continuously provide a tear-resistant lubricating film within the bearing area at both high speeds and high temperatures.
SAPS (sulphated ash, phosphorus and sulphur) content is necessary to help keep the engine oil’s Total Base Number, resist thermal breakdown and viscosity shear, and protect against wear, oxidation, deposit formation and corrosion.
Sulphated ash is the metallic content remaining after engine oil combustion. These particles are mostly formed by the engine oil’s detergent and anti-wear additives. As sulphated ash deposits aren’t combustible, regeneration doesn’t remove them, leading them to collect in the diesel particulate filter (DPF) or other such device used for exhaust aftertreatment.
When sulphated ash becomes too concentrated, it can block the filter, causing loss of engine power and functionality. It can also cause formation of deposits on internal engine components, which can result in engine damage.
Phosphorus is an engine oil additive that provides anti-wear protection and enhanced oxidation resistance. Phosphorus creates a thin layer over metal surfaces, which limits friction between metal parts. Sulphur is another additive that promotes engine cleanliness, but also supplies antioxidant and anti-wear protection.
However, regardless of these favourable characteristics, when sulphur and phosphorous concentration is too high, it can poison and cause damage to a vehicle’s catalytic converter and lead to a build-up of sulphated ash within the engine and DPF.
ACEA C2 engine oils​
C2 class lubricants are considered stable and stay-in-grade engine oils. They have a mid SAPS level and are used as catalyst-compatible oil in vehicles with all modern aftertreatment system types and engines in petrol-powered passenger cars and light duty vans, as well as Direct injection (DI) diesel engines that are designed to use low viscosity oils with a minimum of 2.9 mPa*s HTHS viscosity.
ACEA C3 engine oils​
C3 class lubricants are also stable stay-in-grade oils with mid SAPS level, for use as catalyst compatible oils with modern aftertreatment systems and high-performance DI diesel engines. However, they are suitable for engines designed to use oils with minimum HTHS viscosities of 3.5 mPa*s.
ACEA C4 engine oils​
C4 engine oils are also formulated for engines that use oils with 3.5 mPa*s HTHS viscosities and are stable catalyst-compatible engine oils classed as stay-in-grade. However, where they differ from both C2 and C3 engine oils is that they are low SAPS level oils.
