Wheel bearing or tyre noise? [Resolved]
Robert Hallyburton
Hi,
I have a 2016 150PS T6 Shuttle and have a droning noise coming from the rear wheels. It peaks at 65mph and stops when I take a left hand curve in the road but remains when I take a right hand curve. I thought it was just tyre noise as there was no play or grinding from the wheels when I jacked it up.
Its high mileage so could be the bearings but looking for some views?
Usually if you can 'play a tune' by varying the load it points to wheel bearings. Can you jack it up and spin the wheel? You might hear or feel the roughness.
If you can’t feel any play it’s probably tyre noise.
Have a Forum search on sound deadening, applying 10mm self adhesive foam to the inside of the plastic wheel arch liners makes a big difference.
Just had my 2016 shuttle mot,d and tester has said my n/s/r bearing is going ,will get it sorted soon, milage is just over 108k ,wonder why it's the n/s/r lol , Al probably just get both done if am honest as mibi it's just a matter of time before o/s goes
