What Rear View Camera ?
Discussion in 'General VW T6 Chat' started by Mavis628, 22 Aug 2018.
  1. Mavis628
    Mavis628 Member VIP Member T6 Pro
    Map
    Hi guys
    After some more advise!
    Lookingto fot a revedskng camera, can someone point me in the right direction of one that with work with My head unit .
    Cymro likes this.
  2. Mavis628
    Map
  3. Dellmassive
    Dellmassive 204 T32 DSG LWB SPORTLINE PV MY18 VCDS User Moderator VIP Member T6 Legend
    Map
    we got ours from here > way cheaper than the £600 factory option.
    Home page | VAG-TEC E-shop
    shipped in from poland, all OEM kit. took a few days to arrive.
    we got this one >
    Genuine OEM Retrofit Kit - Rear Camera - Twin Barn Doors - T6 Transporter
    Genuine Volkswagen OEM Retrofit Kit - Rear View Camera - VW T6 | VAG-TEC E-shop
    NEW VW T6 - Rear View Camera KIT - With Guidance Lines - Retrofit -
    See behind your car with rear view camera.
    A camera at the back of your car shows you what's behind to make reversing safer and easier. Or rear view camera lets you spot any obstacles behind your car - even moving ones - quickly and easily, thanks to the rear view camera.
    The camera starts working as soon as you put your car into reverse gear. It shows the area behind your car on your radio or radio navigation system display offering you a clear reversing image with easy-to-follow guidelines. Superimposed graphic lines guide you to the optimal steering lock, guaranteeing fuss-free, smooth parking.
    Using the rear view camera means you'll be able to manoeuvre quickly and easily, even into the most difficult parking space. It also alerts you to low-down obstacles which parking sensors cannot always detect. The reversing camera is also a great help when you're hitching up a trailer.
    Compatible with Head Unit:
    Composition Media
    Discover Media
    Discover Media Plus
    Note:
    After installation you need to code the system.
    Please contact your local VW dealer or workshop with diagnostic software ( VCDS or ODIS ).
    Availability:In stock
    Estimated Shipping: 1-2 Days
    Weight: 1.5 kg
    Installation Time: 3 Hours
    Item Condition: New
    Fitting Instructions: Available
    Required Fitting Expertise: Medium - Some Fitting Skills Required
    Warranty Period: 12 months
    It come with a new rear plastic cover with the camera already mounted. but we have colour coded plastics, so we plan to fit the camera in our painted part - still yet to do this bit.
    The loom come complete, even with the pins ready to be connected to the rear ISO block on the Nav.
    Edit -
    the cable run was ok doing a bit of fishing here and here.
    remove the rear door panel, run cable through existing door loom boot.
    fish cable from behind rear light up to upper tailgate hinge cover.
    fish cable above roof lining with existing loom all the way to the front.
    fish cable across cab roof lining and down A-pillar.
    fish cable behind glovebox to rear of nav.
    LDZ likes this.
  4. Mavis628
    Map
  5. Mavis628
    Map
    Thanks for reply, anywhere I can get one by the weekend as the van is on Monday having the back insulated could do with the wires going behind the carpet ?
  6. Dellmassive
    Map
  7. Mavis628
    Map
    Thanks again the media station in my van hasn’t got navigation, will it work, not sure it’s discover media if it’s not got nav? Could I put a non genuine camera on it? How would I find out if my head unit will support the image
  8. Dellmassive
    Map
    looks like you have :
    02 Composition Media DAB+ radio system
    and the one i linked in at the top looks like its compatible
    Composition Media
    Discover Media
    Discover Media Plus
    edit:
    no i dont believe you can add a third party camera without some major tweekage, the it seems to be a standard CVBS signal to the headunit and a trigger from the rear reversing light. so never say never.
  9. Pauly
    Pauly Senior Member VCDS User Admin Moderator
    Map
  10. Dellmassive
    Map
    awesome, sorry @Pauly totally forgot about that one.
    i had the barn door remember so the tailgate option slipped my mind.
  11. Eddcameron
    Eddcameron Member Trade Member VIP Member
    Be a little cautious of this company Vagtec. I used to deal with them years ago under a different name. They are crooks and will never resolve any of your problems. Also not sure where they source there stuff from. His name is Tom.WARNING
    andys, DaveyB and Mavis628 like this.
  12. Mavis628
    Map
    I have barn doors but mine is a lwb.
  13. Pauly
    Map
    I would echo this, have had dealings with them and they are awful, they will lie to you and pretend to be in the UK etc etc, they are not, all they want is your money and they will not help if theres any issues
    andys, DaveyB and Eddcameron like this.
  14. Dellmassive
    Map
    can we clarify it its this place i ordered from in poland....
    Home page | VAG-TEC E-shop (no h at the end)
    or this place with a very similar name but different company?
    VAGtech Limited - Specialists for VW, Audi, SEAT, Skoda
    who have you had agro with?
    Mavis628 likes this.
  15. Pauly
    Map
    The top one where you ordered your stuff from, Tom the t**t
  16. Dellmassive
    Map
    LOL, right ok. ill bear that in mind in the future.
    No problem with our order or delivery..........but i haven't 100% installed it yet so still untested.
    Pauly likes this.
  17. Pauly
    Map
    I’m sure they have many satisfied customers it’s just the ones where things don’t go right or there’s an issue, they will lie and cheat and offer no help/support etc and wash their hands with you as they already have your money
  18. Gareth1
    Gareth1 New Member VIP Member
    Map
    Hi, does anybody have any photos of their camera installed? I have a T6 and would rather not but the vehicle to install. Looking for a decent number plate light mounted one. Any pics / specs appreciated
  19. Dellmassive
    Map
    as per your other post - Tailgate or barn doors?
  20. Gareth1
    Map
    Tailgate sorry. I should have said.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
